× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX6200 connection/login issues with latest firmware update
Angimator
Hello, I just recently installed the latest firmware upgrade for the EX6200, and after doing so when I am prompted to login to the mywifiext.com/net webpage, when inputting my login info for Netgear, nothing loads after putting my info, I am stuck on the page. What should I do? The light on the router that is green is the device to extender. Thanks. And if I have to revert, how do I do so?
Model: EX6200|AC1200 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: EX6200 connection/login issues with latest firmware update
Hello Angimator
In order to reset the device you should see a small pin hole on the extender you will need a pen or paper clip and hold down the reset button for 10 seconds to factory reset then try to setup the extender again.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2677 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
