×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
EX6200 loses connection to primary router on Windows 10
dk2463123
Have the EX6200 set as an extender via WiFi then using ethernet connection to my PC. When I cold boot the PC, the 2.4Ghz link and the Device connection lights are green. Once the PC boots, the connections remain green but I have no internet connection. After a couple of minutes the 2.4Ghz goes to amber and the Device connection remains green. This then stays that way. When the Ex6200 is in this state I can still use the primary router on my mobile as well as via WiFi on my laptop so I know the primary router isn't down or the issue.
The only way to resolve is to disable my ethernet and reboot the EX6200. Once the EX6200 finished rebooting and reconnecting to my primary router and I enable ethernet, it works but will then drop the connection to primary for a minute or 2 (2,4 Ghz goes amber) then reconnects.
Any ideas?
thanks
Message 1 of 2
nhann
NETGEAR Employee Retired
Re: EX6200 loses connection to primary router on Windows 10
Message 2 of 2
Discussion stats
  • 1 reply
  • 2995 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
