- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX6410v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
My extender was working perfectly until there was a power cut and now the Router Link LED is not lighting. what do I do?
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your responses.
Actually the solution turned out to be very simple. Because the problem started after a power cut and obviously my router and extender re-started immediately power resumed, the extender couldn't connect to the router because it was still booting up. before committing to a factory reset I turned off both router and extender, re-started the router and after it was stable switched on the extender and everything worked beautifully.
I hope this might help someone else who experienced problems after a power cut.
Max
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6410v2
Other LEDs OK?
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Begin with the Quick Start/Installation Guide.
Check the section in the manual
FAQs and Troubleshooting
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
For more help with this device, try the appropriate community section:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
Just another user with time on their hands.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6410v2
Have checked Manual and FAQs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6410v2
, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
- Mark as New
- Bookmark
- Subscribe
- Permalink
Max
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6410v2
glad you got it working! You might mark your response as the accepted solution so others aren't trying to fix it still and so they know the fix 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX6410v2
@Max1942 wrote:
....before committing to a factory reset I turned off both router and extender, re-started the router and after it was stable switched on the extender and everything worked beautifully.
Good move.
That's a standard move after an unexpected reboot.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
User | Count |
1 | |
1 | |
1 | |
1 | |
1 |
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
