- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7000 As Access Point SSID Naming
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a C7100V DOCSIS 3.0 Cable Modem Router + Voice with Xfinity in the basement. I have an EX7000 connected to it on the first floor with a Cat5 connection. The 2.4 frequency on both has the same SSID (named F2) and the 5.0 frequency have the same SSID (named F5). They seem to share the SSID name OK. My first question is, Is there any risk of having the same SSID's? I have a cat5 wire run to my barn and also to the second floor on the other end of the house. I have 2 old N routers at each of those spots. I am considering buying 2 more EX7000's to alos run in Access Point Mode with the cat5 connections. I currently log into the router with www.routerlogin.com and log into the EX7000 with www.mywifiext.com. My next question is, If I have 3 EX7000 Access Points, how do I login to each one if I would need to make an update? Would I have to know the IP address? My final question is , What would happen if I name the SSID's the same for the 2.4 (F2) and the same for the 5.0 (F5) across all of the devices? Would the WIFI connection switch between AP's as I move throughout the house?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7000 As Access Point SSID Naming
The main risk is that the client devices might switch back and forth if they are in the overlap area for coverage. Most clients won't have that problem though - there are lots of places where there are multiple APs with the same SSID (hotels, airports, etc), so generally speaking clients handle this pretty well.
If you connect to the extender network, then mywifiext.net should always get you to the correct extender. But I suggest reserving IP addresses in the router, so you can manage the extenders from any location.
It should, but there might be times when you need to manually reconnect - for instance, toggling wifi off/on in the new location.
Another approach (likely more expensive) is to go with an Orbi system. Not sure how many satellites you'd need to cover the entire space.
