× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7000 Extender as Mesh Network Access Point
Webb_J
I am currently using an R7000 router with an EX7000 extender.  Up until a few weeks ago I had them setup as separate wifi names but after reading about the new firmware updates I did the updates and set the EX7000 into MESH mode.  I can not connect devices to either device and it works great until you move closer to the other device.  It appears it's not allowing devices to switch from one access point to the other without manually turning off wifi on the device then reconnecting to the nearest access point.  How do I resolve this issue?
Model: EX7000|AC1900 WiFi Range Extender
Message 1 of 4
Guru
Re: EX7000 Extender as Mesh Network Access Point
Lots of folks are struggling with the 1.0.1.78 firmware.  I suggest downgrading back to 1.0.0.66 and see if that resolves your issues. https://kb.netgear.com/000059563/EX7000-Firmware-Version-1-0-0-66
Message 2 of 4
Webb_J
Is MESH still available if I go back to that firmware?
Message 3 of 4
Guru
No.  But a mesh that doesn't work correctly isn't of much use to you.
Many users here have gone back to that firmware for now (until Netgear solves the problems with 1.0.1.78).
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1410 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
