charlesle
Dec 31, 2015Tutor
EX7000 - Firmware V1.0.0.38_1.0.91
I used the update feature and discovered V1.0.0.38_1.0.91.
Can anyone explain what this update does? I haven't been able to locate it on the website. Apparently it adds support for region IN/3. What is that?
- Babylon5NETGEAR Employee Retired
You are quite right, I can’t see it available via the ‘Downloads’ option at the top of this web page.
I have an EX7000 at home and will check this weekend, I’m away from home at the moment.
Sometimes there is a delay between downloads being available at the location where routers/extenders look, and the ‘Downloads’ link above.
Well I see the same as you, available in a search at the extender, but not in the Downloads area. I will wait a few days since it’s the Christmas holiday period and if the issue persists I will point it out to Netgear.
