× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX7000 - Internet drops on iOS devices on newer firmware
VS228
Tutor
On any firmware newer than V1.0.0.68_1.0.128, the internet inexplicably drops on iOS devices. The same network does not have any issues on Android smartphones/Windows laptops. I just tried the latest firmware V1.0.1.90_1.0.156 to check if the problem had been sorted out, but, unfortunately, it had not. With the newer firmware, internet connectivity is restored only after a reboot of the range extender.
Model: EX7000|AC1900 Nighthawk WiFi Range Extender
Message 1 of 2
Guru
Re: EX7000 - Internet drops on iOS devices on newer firmware
After the update, have you tried factory resetting and reinstalling?
Are you installing using wps or using the installation assistant?
Message 2 of 2
Discussion stats
  • 1 reply
  • 425 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
