× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7000 Still a problem in 2019
Gel32sor
Initiate
It is 2019 and it is still at it. The EX7000 Range extender is still having issues after firmware update!!! Even after following all the suggestions and fixes from 2018 and 2015 from all the good people of ths community, it is still a failure!
Internet connectivity issues are still happening even with a good connection between the device (PC, phone, tablet) and the extender as well a a good connection between the extender and the router.
Is there an actual member of the Netgear staff watching this forum?
Model: EX7000|AC1900 Nighthawk WiFi Range Extender
Message 1 of 4
Guru
Re: EX7000 Still a problem in 2019
There's the occassional Netgear moderator on here.
1. what router are you connected to?
2. How much area are you trying to cover?
3. How much wireless interference is there? (how many networks if you do a scan)
4. What housing materials is your house made of? plaster lathe, concrete, brick, foil lined insulation, hvac all do a great job of blocking signals.
5. how long is the connection down for?
6. what speeds are you paying for?
7. What speeds are you getting?
8. Modem you're using?
Message 2 of 4
Gel32sor
Initiate
Thanks for responding to my post ...
The extender was working perfectly fine until like the weekend of the 14th of Sept 2019. Below are answers to your questions ...
1. what router are you connected to? NETGEAR AC1900 Cable modem w/ dual band wi-fi
2. How much area are you trying to cover? less than 2000sqft
3. How much wireless interference is there? (how many networks if you do a scan) We have a fully occupied neighborhood so there are about 10 active networks which are constant. Then again it was only until the 14th when I started having the problem.
4. What housing materials is your house made of? plaster lathe, concrete, brick, foil lined insulation, hvac all do a great job of blocking signals. Standard California building materials that has been there the first time I operated the extender and it worked perfectly
5. how long is the connection down for? since the weekend of the 14th of Sept.
6. what speeds are you paying for? 175Mb/s
7. What speeds are you getting? up to 175Mb/s
8. Modem you're using? NETGEAR AC1900 Cable modem w/ dual band wi-fi
Message 3 of 4
schumaku
Guru
The 1.0.1.80 firmware released this summer was certainly better than the one from almost one year ago. There was some more work ongoing to address problems with the dynamic key rotation since. If you can, you might want to disable the key rotation on your wireless router for the moment. Unfortunately Netgear seems to have very limited engineering resources, it was said that this update should become available end of September/early October.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1698 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
