× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7000 Wifi Range Extender - Antenna change for longer range
Fern007
Follower
I have a NETGEAR EX7000 Nighhawk Wifi Range Extender. It comes standard with 3 antennas (I think of 5dBi of gain).
Question:
1. Can I change all 3 antennas to a higher gain one? 11dBi?  Where can I buy them?
2. Could I change "only one antenna" for a directional panel antenna which I will point to the router source direction? and keep the other 2 antennas standard.
Any suggestions are welcome...objective is increase signal level "reception" from router from clubhouse which it is 500 feet away.
Model: EX7000|AC1900 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: EX7000 Wifi Range Extender - Antenna change for longer range
Netgear does not support the use of Third party antennas use at your own risk.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1641 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
