× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
EX7000, loss 5Ghz SSID / all connected devices
mrund
Follower
Been using my EX7000 as an accesspoint, both 2.4Ghz and 5Ghz for clients.
The EX7000 is connected with wire.
Once a week or every second week at least, all clients connected to 5Ghz will loose the connection and the SSID is not visible any more.
Only a restart solves the problem, also seen the 2.4Ghz drop all connections and SSID gone, once but never again.
Using two different SSID, one for 2.4 and one for 5ghz, so I know which one that disappears.
As I have it connected to the wired network as well, I can log in and do a restart.
Currently at: Firmware Version V1.0.0.38_1.0.91
Any suggestions?.. Did notice that the R7000 had the same problem when I searched the forum, but no luck with a workaround/fix.
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: EX7000, loss 5Ghz SSID / all connected devices
Hello mrund
I would try to change the wireless channel? also I would try a factory reset on the EX7000 see if that helps with the issue.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3198 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
