- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7000 no internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7000 no internet connection
If you just bought it - send it back !!! I never had a problem with mine until very recently. There's still this lingering thought in the back of my mind that I hit one of those bogus netgear sites... but the more people I hear from the less I think it's likely. The only thing that I've read so far that makes any kind of sense is that there's code in the routers to prevent double NAT'ing in Bridge mode - but it makes no sense in an AP or Range extender. What I continue my scratch my head over is access point with a phone home requirement. I checked my router logs, and the traffic isn't blocked. The reason that I'm looking to replace it is that I'm starting not to trust it. I pay a decent amount of money for my commercial grade networking equipment at home - just for this reason. I have restrictions on my router that limit me to single wireless access point on my wireless port - I use an existing weaker acecss point on my low side for that (I'd rather have the stricter controls on that subnet). If I dont get an answer, Netgear is out of my picture for good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am experiencing the same issue with the web-control of the EX7000 reporting no internet connection.
I tested and confirmed that I am in fact connected to the internet when I am connected through the EX7000. I achieved this by changing the SSID to a new name that is different from the R9000 and the other EX7000 in my network setup. (quick note, both EX7000 report no connection)
When I connect to the EX7000 I am able to use all internet connected software on my MacBook. So it is just an issue with reporting correct status (at least in my case).
I have attempted to drop back versions of firmware on both the EX7000s and the R9000. No change. I also just updated to a new firmware version, for the R9000, that dropped recently. This did not fix the issue.
One thing I can share, not sure if it is important or not. When I initially setup my network with the R9000 and the two EX7000s it was reporting correctly on the EX7000s. No changes were made to either router as far as firmware. (When I was installing the R9000 it forced an update of firmware, one back from the most current, but it was working after that). I am not sure when it fell to reporting incorrect internet connection status. The R9000 has always correctly reported that it has an internet connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
D0gg,
If you look back on this discussion I put a reply on the 30th April. I put both my EX7000 and R8000 back two firmware versions and did a full factory reset and still had the same no internet connection message.
Any of your EX7000 still under the 90 days warrenty so you can raise a call?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Already made a call. Spoke with a person I could barely understand... stepping me through the steps I had already done.
And yes, I did see your reply. I was just offering up my experience to others with the possiblity that something I did might spring forth a thought of something new to try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
They are attempting to replicate the issue first before reverting on the possible root cause analysis. Hopefully this will get them to look into a solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I also have the same problem. No solution as yet, but I am hoping someone might come up with a solution on this thread.
I have Virgin Media hub set up as a modem connected to a R8000 with a wired connection to an EX7000 as a WiFi extender.
R8000 firmware: V1.0.3.36_1.1.25 (updated last week)
EX7000 firmware: V1.0.0.50_1.0.102 (updated just now)
I did a belated firmware update on the R8000 because of the well publicised security issue a few months back. Thought I should check the status of the EX7000 this week.
Strangely, when I logged in, the EX7000 was already showing that I had 'no internet connection'; but I knew that wasn't case as I had more than one mobile device successfully connecting through it. So I thought I would update the firmware and hoped it would solve this error message. Bizarrely, after updating the firmware successfully on the EX7000, not only does it still report 'no internet connection', it is no longer able to 'check for updates', reporting the lack of internect connectivity as the reason (whereas, just minutes earlier it had managed a successful update over the same connection)!
I can still connect my mobile devices through the EX7000 and via the R8000 to the internet, so I am not suffering any loss of functionality. One odd aspect I can see is that the EX7000 is not recognised as an 'attached device' on the R8000. In the Basic display of attached devices on the R8000, all devices wirelessly connected to the EX7000 shows up as wired connections on the R8000. The EX7000 appears invisible to the R8000.
I am beginning to wonder if I should have just left everything alone and not messed with it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
Thank you for your quick reply and description. I am pretty often on my router, Fritz 7490, very common in Germany. And here I go from time to time on the Extender.
And today the problem! Nothing changed, no updates, nothing!
What happened, what's going on. I also tried everything possible: reboot, reset, reinstallation, different configuration ....
Nothing helped.
And:
I have the extender for about 4 months, with the latest Firmware, NOTHING CHANGED! (also by Router not)
Only hope remains.
With kind regards Frantisek
- Mark as New
- Bookmark
- Subscribe
- Permalink
Out of curiosity what OS are people running, could this be OS related?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I too have had these NetGear items for several months without problems. I really suspect this is something to do with the firmware OR that we are all victims of some kind of cyber attack!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
PC with Windows 10 Home new Version
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think its unlikly the OS is at fault but the Windows Creators update was the only recent change to my system and i only noticed the not connected to the internet error sometime after that. The firmware on the extender has not changed and if its a cyber attack its not a very good one since everythings still working for me i just get an error telling me its not connected. Can you confirm you get the same error on a Mac?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep. I am checking the status using Safari on a Mac.
Says it has no connection to the internet, but it does.
- Mark as New
- Bookmark
- Subscribe
- Permalink
well that rules out the OS for sure
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The OS was a long shot but it was the only thing that had changed recently, i agree it has to be something on the access point . I am going to quiz the network engineers in the office to see if they know how these things verify they are connected to the internet. its strange as everything works fine, i have a couple of cloud based cameras hooked up to this and i get an email if they disconnect but they have been rock solid.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the network techs at work all said its most likely failing to reach a site to verify connectivity as previously mentioned by someone else, they suggested i disconnect everything else and just have the extender connected to the modem router and look at the logs to try and determine what its trying to look at and then put in a static DNS pointing it somewhere else.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
were you able to find out what address its looking for?, if it is something this basic you have to wonder why netgear have not addressed it already
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue. Wired AP, works 100% fine, WIFI and ethernet connections. BUT reports no internet connection when connect to the UI. Super strange, but if it's working 100% ok WIFI and ethernet as an AP off of my Asus router through our wired home then I guess it's ok. Just odd... must be an UI bug of some kind.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Question for everyone in the thread: does anyone else besides me use Avast? I was looking through my router logs and I have a malformed DNS packet trying to connect to Avast. By the way, I confirmed, I gave the range a static IP and DNS and still fails. I pulled the picture because someone may have picked up my MAC address from it - but what I had was a malformed DNS request from a different network provider to an Avast server through my network. I'm a bit concerned.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope, Bitdefender
going to trawl through my logs when i get home tonight and see if there is anything strange going on. if i have time i am going to isolate the EX7000 clear the logs on the Cable modem/router and see what its trying to do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well then we can rule out that then. It was worth a shot. Thanks.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
