× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
EX7000 no internet connection
NGGJ
Re: EX7000 no internet connection
I am using Avast.
Looks like I don't have anywhere near enough IT knowledge to work this out. I wouldn't know how to identity a malformed DNS request if it hit me.
But I'm happy to help with any testing- just let me know what I can do!
Message 51 of 137
AJCrowley666
Guide
The more info we have the better, i have cleared all my router logs and will look though them tomorrow to see if anything stands out
Message 52 of 137
AJCrowley666
Guide
so the router logs show nothing interesting, i still think that it may be failing to  reach a site to verify access but i cant identify it.
what if (its a big if) the site used to verify is now ip6 only, my provider does not support ip6 for residential customers (Telstra, Australia)
you can test using this link
http://test-ipv6.com/
you can also see by checking the ethernet properties of your network card, probably another long shot
Message 53 of 137
DrCharlesForbin
Apprentice
I'm going to check tonight now that I have the Mac addresses for the access point.
Message 54 of 137
NGGJ
Did the IPv6 test and failed.
My provider in the UK evidently does not support it at this time.
Message 55 of 137
AJCrowley666
Guide
There are not many ip6 only sites from what i can tell so its not an issue yet but i am just trying to identify a common denominator.  From what i can tell there is some tunneling trickery that goes on to support this and perhaps somethings gone astray, still a long shot and i am sure someone with better networking skills would have a better idea
Message 56 of 137
Wiltshs
Guide
Same issue Virgin Media in the UK does not support IPv6 and sure this is not the issue anyway. Did have a look on my Netgear R8000 to see if I could bridge IPv4 to IPv6 but you cannot, only the other way around and not going to help you.
I still think it’s a call home feature at firmware level and could be as simple as a security certificate has expired at the Netgear end but would expect to see a HTTPS request go out on the firewall logs and I could not see this but that does not mean Netgear may filter this out for us not to see this?
Answer other posts – I have Kaspersky Total Security 2017 for AV and Windows 10 Creator Edition for desktop and Laptop but also same error message on Android tablet version 6.
Model: EX7000|AC1900 WiFi Range Extender
Message 57 of 137
AJCrowley666
Guide
yeah i think the whole ip6 thing was a long shot but running out of ideas. i was going to say something about what do you expect when you use an internet providor that does not go all the way 🙂
i can also see nothing on my router logs, i cleared them first so i started with a clean slate but so far nothing useful.
i am surprised by the lack of answers from Netgear as this may well be something very simple
Message 58 of 137
AJCrowley666
Guide
found this after searching for the home feature you mentioned
https://community.netgear.com/t5/Smart-Plus-Click-Switches/GS108Ev3-calling-home-quot-feature-quot/t...
Message 59 of 137
DrCharlesForbin
Apprentice
Not a damn thing in my router logs.. not even trying to get out.
Message 60 of 137
AJCrowley666
Guide
same, i am now looking at the page source code  to try and see whats going on, i can see the function call but cant seem to find any more
('body').msgload();
          $('body').msgshow("Checking the Internet connection; please wait …");
          $.ajax({
            type: "POST",
            url: "ajax/get_internet_status",
            data  "action=getStatus",
            dataType: "html",
            success: function(data) {
              if (data != "1") {
                $("#title_string").html("<i class='icon-errormark'>");
                $("#title_string").append("Your access point has no Internet access. Check to make sure that your router has an Internet connection.");
                $("#cc_red_cross").addClass('redCross');
Message 61 of 137
Frantisek
I GOT IT! Smiley Happy
True, it is related to IPv6.
In my router FRITZBOX 7490 gives it the possibility to join them. And my IT provider supports them as well.Smiley HappySmiley Happy
IPv6 support IPv6 support IPv6 connectivity Native IPv4 connection (recommended) First, a native IPv4 connection is established. If a 6RD server has been learned via DHCP, a 6RD tunnel is established. Otherwise, an attempt is made to establish a native IPv6 connection (dual sta
Thanks to all and much success!
Greetings from Germany
Frantisek
Message 62 of 137
AJCrowley666
Guide
Hi Frantisek
great news i think, can you confirm you no longer have the no internet connection message?
Message 63 of 137
Frantisek
 Hi AJCrowley666
The Netgear Ex 7000 I have about 4 months, as access point, equal from beginning with the newest firmware. Everything went great, and very good signal.
All devices always well connected, without signal or speed drop. (1 PC with Windows 10, 1 PC with W7, Smartphones with Android).
And then I did not look so often at Netgear genius. Then I have on my PC Windows 10 updated to the latest version, as I noticed: no internet connection, although Internet was always there! When exactly has this happened and why, I do not know unfortunately
Regards
Frantisek
Message 64 of 137
DrCharlesForbin
Apprentice
Ok - next question. How is your access point directly talking to the provider without being NATted?
Message 65 of 137
DrCharlesForbin
Apprentice
Just read my router doc - they have instructions for creating the 6RD tunnel.  I'll try it tonight and let you know if I have any success
Message 66 of 137
Wiltshs
Guide
I configured my R8000 under advanced setup IPv6 set 6 to 4 Tunnel and yes, the EX7000 can now see the internet - no more error message, no reboot required instantly worked.
My ISP does not support IPv6 so regardless of this working Netgear especially for the UK need to still set IPv4 as the default!
Netgear we have found the answer to your problem now can you fix this please.  I must be honest though I am still not happy with the call home feature anyway and we should have an option to turn this off.  If not this extender is going to end up on eBay in the next few weeks.
Well done to everyone involved if you have a support call outstanding then need to point them to these posts.
Message 67 of 137
DrCharlesForbin
Apprentice
Thank you everyone and Netgear should pay you for your time 🙂
Message 68 of 137
Wiltshs
Guide
DRCharlesFobin - I still like the 6rd tunnel this may be a better option interesting though I set IPv6 to auto and it liked IPv6 to 4.
Report back later
Message 69 of 137
Wiltshs
Guide
I cannot get 6rd running ISP does not support.  So could leave it in IPv6 to 4 but ISP does not support this but it does seem to work?
I could not get Netgear Genie working and able to log into the router befire changing IPv6 to 4 setting and now I can!
So Netgear have gone full IPv6 but not all ISP's can support this so still need to fix this issue.
Message 70 of 137
NGGJ
For those less talented than yourselves, would any of you have the time to put together an idiot's guide on this 6RD solution, please?
Or should we who are less skilled be better if simply wait for another firmware update?
(Given that there is almost no loss of functionality - apart from the EX7000 itself not being able to check for and install its own updates, so users will have to download and manually, via the R8000 in my case, install any future updates)
Message 71 of 137
AJCrowley666
Guide
i agree, great result and well done to all for taking the time to investigate. sadly my Telstra Cable modem does not seem to give me many options to fix this but i understand native support is around the corner and in the end for me it still works, i just have an incorrect status screen on the access point.
Message 72 of 137
DarrenM
Sr. NETGEAR Moderator
There is a known issue with the no internet connect errors on the  EX7000 a fix is coming in the next firmware update.
DarrenM
Message 73 of 137
DrCharlesForbin
Apprentice
Well, I set up a 6to4 Auto Tunnel on my router, no difference - still blocked. I either have to relay it - anything but 2002 requires a seperate relay - or try a 6rd.
Message 74 of 137
DrCharlesForbin
Apprentice
if it helps - try this link. It's confusing to me too - and I'm in IT - not the network side though.  The main to keep in mind is that it actually does function - this is just an annoyance.
http://help.sonicwall.com/help/sw/eng/6110/26/2/3/content/Appendix_D_IPv6.130.4.htm
Message 75 of 137
Top Contributors
Discussion stats
Announcements
Orbi 770 Series
