× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7000 question
Parma5551212
Follower
EX7000 question
Can I use this EX7000 Range Extender in Fast Lane Technology mode for the following use. WIFI source  is a LG V10 (android phone) running as a hotspot. I can only broadcast either in 2.4ghz or 5 ghz but not both.
In Fast Lane, I would like to connect the EX7000 to the LG V10 hotspot broadcasting in 5GHZ and EX7000 rebroadcasts the WIFI connection in 2.4 ghz.
Is this setup possible with the EX7000 Wifi Extender?
Model: EX7000|AC1900 WiFi Range Extender
Message 1 of 2
Accepted Solutions
Guru
Re: EX7000 question
Yes.
http://www.downloads.netgear.com/files/GDC/EX7000/EX7000_UM_EN.pdf  wrote:
When you enable FastLane Technology, two options are available:
  • Use the 2.4 GHz band to connect the extender to the WiFi devices and use the 5 GHz band to connect the extender to the WiFi router. Use this mode if your WiFi router supports the 5 GHz band but the devices that you want to use for gaming and streaming support the 2.4 GHz band.
  • Use the 5 GHz band to connect the extender to the WiFi devices and use the 2.4 GHz band to connect the extender to the WiFi router. Use this mode if the devices that you want to use for gaming and streaming support the 5 GHz band but your WiFi router supports the 2.4 GHz band.
Message 2 of 2
All Replies
Guru
Re: EX7000 question
Yes.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1104 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
