× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
EX7000 wifi extender - I need to keep rebooting device.
BooYah
Tutor
I need to keep rebooting my device to make it work.  All devices lose connection as device does not recognize password.  After reboot the device will work for about a day then devices lose connection again.  When devices lose connection I cannot reconnect to routed - error message says incorrect password.  After reboot everything works fine for about a day
Message 1 of 21
Guru
Re: EX7000 wifi extender - I need to keep rebooting device.
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 2 of 21
BooYah
Tutor
I set it up manually
Message 3 of 21
Guru
what router are you connecting it to?
Message 4 of 21
BooYah
Tutor
I am connecting to an Xfinity XB8 router
Message 5 of 21
Guru
Make sure the xb8 is set in wpa2/wpa3 mode and that its not using dfs channels.
Message 6 of 21
BooYah
Tutor
Confirmed
Message 7 of 21
BooYah
Tutor
Still having issue
Message 8 of 21
Guru
what speed do you have set on the xb8? for 5ghz speed.
Message 9 of 21
BooYah
Tutor
How do I determine the speed
Message 10 of 21
Guru
You'd need to check with xfinity to see how to check their wireless speed settings for 5ghz. I could tell you with a netgear but not the xb8
Message 11 of 21
BooYah
Tutor
I only connect using the 2.4 ghz band to the EX7000. The bands are split on the XB8 router
Message 12 of 21
Guru
2.4ghz is a slow band that is sensitive to interference because so many things broadcast on it. using only that for a backhaul will cause slow downs/drops.
Are you using fastlane or why did you set it up with the 2.4ghz only?
Message 13 of 21
BooYah
Tutor
My video cameras only work on 2.4ghz. I never had a problem with this configuration until recently.
Will the EX7000 accept a merged WIFI 6 signal and split out a 2.4ghz band?
Message 14 of 21
Guru
Just set it up in the default mode.
Or if you're using fastlane, you can set the 5ghz to be the connection between router/extender.
Message 15 of 21
BooYah
Tutor
Just so I understand. The EX7000 will extend the three band XB8 WiFi 6 signal and the EX7000 can be split the incoming three band signal into a separate 2.4ghz. Is this a correct understanding?
Message 16 of 21
Guru
The EX7000 isn't triband (or 6ghz at all).
So it won't pickup the XB8's 6ghz band.
It will pickup the 2.4ghz/5ghz and rebroadcast those just fine.
Message 17 of 21
BooYah
Tutor
If the signal is sent as a combined single band can the EX7000 split and retransmit the 2.4ghz and 5ghz into separate bands with unique and nameable SSIDs
Message 18 of 21
Guru
yes it can. Just use the installation assistant for setup and not wps.
Message 19 of 21
BooYah
Tutor
What is the URL (location) for the installation assistant?
Message 20 of 21
Guru
here's a video of using it.
Message 21 of 21
Discussion stats
  • 20 replies
  • 2772 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
