- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7300 5 GHz channel
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear collegues,
I´ve my EX7300 -configured as a AP- connected over a ZYXEL GS1900-24E switch to an AVM router 7490; FW V1.0.2.152.
Now I want to use a chanel => 100 in the 5 GHz band but it is not possible to choose such a channel in the configuration menu.
The range to select is from 36 to 48 only. (with a EX6150 such a selection is possible).
Has anybody a solution ? Many thanks in advance
Gerd
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7300 5 GHz channel
Which firmware are you on and what region are you in?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try downgrading to version 1.0.2.140 (if you're on version 1). I've seen a couple posts with issues on the newer firmwares with dfs channels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The 7300 firmware is 1.0..2.152 and my region is Europe (Germany).
Thanks for the quick reply, I´ll try to downgrade the FW and let you know if it´s the solution.
Gerd
- Mark as New
- Bookmark
- Subscribe
- Permalink
After the downgrade, make sure to factory reset and do a clean install (not from a backup)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi There,
I can confirm, that issue still persist also in recent version of firmware 1.0.2.152, without any update from vendor side.
Already contactacted Netgear Support multiple times, but they doesn't care because my device out of waranty.
My original escalation, with steps how to reproduce the issue is avaliable here:
It doesn't make sense to downgrade Firmware to version 1.0.2.140, this version is nearly 3 years old with a lot of security bugs.
M.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just made the fw downgrade to version .140, a factory reset and a clean reinstall as recommended. You are right this was the solution and the dfs channels are available now.
I hope there are no security leaks in this fw-version. Anyway, thanks a lot for the quick help.
Friendly regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey, but downgrade is not an solution!
Event, it's hard to tell that's workaround, version .140 contain major security vulnerability, besides other minor issues with iOS devices roaming. We need an official fix from Netgear.
In the last couple of years, I feel like Netgear beta tester with their firmware releases. Maybe it's time to take a look for another vendor.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Feel free to try another vendor.
I've used several other major brands. 2x of them didn't give ANY updates after releases on major flagship devices. Not saying they're all that way but at least netgear is still trying to update products/fix bugs. And I've been involved with beta testing with great results. But the more complicated devices get, the more bugs/issues you'll find.
so while I agree and I don't feel netgear does quite enough on bug/issue fixes, compared to others I've used, its been better.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I Agree.
Reason why I'm upset on Netgear in this case is that I've opened the issue nearly 2 years ago (in 2019), when issue appears in FW version .144 and in these time my device was under full waranty. Without any notice they have closed my issue after one year as "Resolved, device out of waranty". When I tried to re-open and remind them an issue they closed it immediatelly because device is not in the waranty but SW issues persists.
- Mark as New
- Bookmark
- Subscribe
- Permalink
