× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7300 - Data lag
Just_y
EX7300 - Data lag
Hi guys
I needed to extend my standard ISP modem/router wifi range so I bought the EX7300 for this specific use.
I plugged in the EX7300 and set it up - got the internet connection straight away - all good from that perspective.
I am using a Frizbox 7390 (v06.53) as modem/router and set up a new SSID for the wifi extender as per their recommandation.
So I have the "A" wifi network provided by my Fritzbox and a "B" wifi network provided by the EX7300 (FastLane mode - 5Ghz in/2.4Ghz out).
My issue is that I cannot upload any file with my "B" wifi network to neither the local network nor any internet cloud service (except Dropbox?!).
I understand this is caused by a misconfiguration within my local network but I can't figured out what to do.
Can someone help me pls?!
Thanks a lot!
Model: EX7300|AC2200 Nighthawk X4 Wall-plug Range Extender
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: EX7300 - Data lag
Hello Just_y
Could be a port forwarding issue have you checked if any of those file services need a port to be open?
DarrenM
Message 2 of 3
Just_y
Thanks DarrenM for your message.
Can be a port forwarding issue indeed but this also happen in my local network.
As far as I understand port forwarding, it works from an internet service to a device in a local network, right?
(against devices in a local network)
Here is my config again:
Fritzbox 7390 (ISP modem/router)            EX7300/AC2200
- wifi network 1                                           - wifi network 2
- smart TV
- TV box
- PS4
- NAS 1
- NAS 2
I can't even upload any file on my NASs.
I am pretty sure it's not a compatibility issue and I know I am doing smtg wrong but can't get where.
Thanks for your help,
y
Message 3 of 3
Discussion stats
  • 2 replies
  • 2354 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
