- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7300 Network Signal Drops
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
So I bought the new EX7300 and all this week there has been nothing but network drops. I think it may have something to do with latest firmware, but I am listing some other steps I have taken.
1.) I downgraded to a firmware version that I remember not having any signal drops.
2.) I made sure that my Linksys 1900ACv1 was set to WPA2 Personal only, not WPA/WPA2. I also changed the EX7300 to WPA2 only as well. That got rid of the message following this sentence. I did this because my EX7300 kept saying that it would only run in N 54MBPS if I use WPA ( I think another bug with the software), because it still gives me that message even though my router is set to WPA2 Personal and my EX7300 set to use "Same pass as network".
3.) I set the EX7300 with a static IP address
So far I havent had any drops since doing the above steps. I am keeping my fingers crossed. Will update after a few days.
If anyone has any other "fixes" post them here. Its really disappointing to buy a really awesome piece of tech for to not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7300 Network Signal Drops
Hi @Sgtkeebler,
Do you experience this drop only on specific band or both? Does it happen on all devices connected to extender? Did you performed reset after firmware upgrade and checked if your issue persist? Do modify wireless channels on your router if your issue persist.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Sgtkeebler,
So you are running firmware version 1 before latest and you don't witness any issues. But you have signal drops on latest firmware?
