Orbi WiFi 7 RBE973
Reply
EX7300 no internet access
Merlin3322
Follower
I have a Netgear router X4 R7500. To extend my network, I thought the best is to buy als a Netgear Extension, thinking this will fit best together. I have bought the EX7400 extension. I installed and configured it. All works fine. If i connect the extension (http://mywifiext.net/) the settings are fine and the both networkworks are setup properly. In the router I can see it also as connected device. All seems OK, but if I connect to the expansion I have no internet access.I have no more idea what to do, its absolutely annoying and the extension is useless.I have also reset the router, installed the extension several times, I had contact with the Netgear support via chat and phone and replaced the extension.
Any ideas?
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: EX7300 no internet access
Hello Merlin3322
Make sure you have the SSID a separate name from the main router. You may also want to try and change the wireless channel on the router to see if that will help.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3455 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
