Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7500 Can’t connect to internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-05-13
04:28 AM
2020-05-13
04:28 AM
We can see it as a wifi option but can’t connect it to the internet. Only second and third lights go blue. Any help would be very grateful
Model: EX7500|AC2200 Nighthawk X4S Tri Band WiFi Mesh Extender
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-05-13
07:54 AM
2020-05-13
07:54 AM
Re: EX7500 Can’t connect to internet
If you go to the manual, it'll tell you exactly what lights they are and what each color means.
it can be found here:
https://www.netgear.com/support/product/EX7500.aspx
Did you set it up via wps or via the installation wizard?
if you used wps, I'd recommend factory resetting and running the install wizard.
what router are you connect it to?
Firmware on the extender?
Message 2 of 2
Announcements
