Aaron1738
Nov 29, 2020Follower
EX7500 no internet connection even though I’m connected
I set up The device and it has signal, even though I am already connected to a network Whenever I connect to my extender (Aarons RV)WiFi name nothing happens no Internet connection so my first thought is to update the firmware when I try to update the firmware it says no Internet connection there is no LAN connection on the device! So now I’m stuck! In my mind I would think it would need an update and I’d plug it into a computer and update it but there is no plugin maybe I’m missing something here!
1 Reply
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
I have asked the Netgear moderator to move your message.
