badhaircut
Mar 11, 2022Aspirant
EX7700 - IP access to Pi from extender
Hi,
I've been trying to headlessly run a Raspberry Pi 4B via an ethernet cable to an EX7700.
The EX7700 extender is wirelessly extending a signal from a stock TalkTalk router using the same SSID credentials and seemingly has been working well.
To access the Pi I need to enter its IP address into a browser. When using a PC connected via ethernet to the router, this all works perfectly. However, when trying to access the same IP using a device connected to wifi this almost never works. It seems like there must be a conflict somewhere but I'm unable to troubleshoot the problem.
I've tried:
- removing the LAN cable and using the on board wifi on the Pi in case the ethernet connection over wifi was causing confusion
- two different Pi operating systems to see if it was a software issue with both having the same issue
- making the IPs static both in the Pi OS and on the TalkTalk router
Both the ethernet and wifi connection to the Pi are visible on the EX7700 web UI and on the TalkTalk web UI.
I feel like there must be a really straightforward setting I'm missing but I'm not sure where to look.
Thanks for any help!
- olympos1625NETGEAR Employee Retired
Hi badhaircut,
We would like to endorse you to NETGEAR Level 2 support team for callback. Please provide the following information:
Name:
Email:
Phone:
Preferred schedule (atleast 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
- badhaircutAspirant
Hi Oliver,
Thanks for getting back to me. I'm happy for the troubleshooting to continue here just in case anyone finds this thread who needs help in the future.I'd also rather not give out my details on what appears to be a public message board.
Thanks
