Reply
EX7700 Router Link - Solid red. Poor connection.
ConfusedOneIAm
Initiate
I have two EX7700's both with the same settings, both in the same room as the router (setting up)... one has Solid white. Best connection. whilst the other is Solid red. Poor connection.
How can this be, same equipment, same room, same distance to router, same settings...?
Is it a faulty device?
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 3
Accepted Solutions
Guru
Re: EX7700 Router Link - Solid red. Poor connection.
Did you shut off the other extender?
Having 2 in the same room can cause issues during setup. I usually recommend shutting down 1 while setting up another one.
CM2000-> RAXE500-> GS716v2-> WAX218-> EX8000
Message 2 of 3
All Replies
Guru
Message 2 of 3
ConfusedOneIAm
Initiate
That could be it, in seperate rooms now and all solid white across the board. Happy days. Internet hasn't felt as strong or fast.
(I also did a firmware update so everything is serviced and tuned).
Thank you.
Message 3 of 3
Discussion stats
  • 2 replies
  • 45 views
  • 1 kudo
  • 2 in conversation
Announcements
