× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7700 - after updating to .216 system does not reboot
MarcLiermann
Initiate
Hi all,
I tried to do the update to .216 yesterday and now the system does not reboot anymore.
Actually the front LEDs are blinking and the rear LED next to the power button in blinking green.
Pressing the reset button has no effect! The rebooting performance starts but it ends in green blinking again... 😕
Does anybody know a work around for hard reset? Can I install the firmware manually in this state?
Many thanks for your help.
Best
Marc
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: EX7700 - after updating to .216 system does not reboot
> [...] the rear LED next to the power button in blinking green. [...]
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
Message 3 of 4
All Replies
Guru
did you push and hold reset for 7-15 seconds while its powered on?
Message 2 of 4
antinode
Guru
example:
Message 3 of 4
MarcLiermann
Initiate
Great! Thanks! TFTP worked well. System is back on track!
Message 4 of 4
Discussion stats
  • 3 replies
  • 822 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
