× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7700 combined with powerline
Chaplain
Greetings to All!
It might be a noob question, but I want to verfy this befor my purchchase.
The house I'm renting (will move in next week, and the provider will hook me up end of next week) has a very weird setup. The router must be placed in the basement but I would need to supply WIFI to the level of the living room and to the level of the bedrooms. So the question is: can I connect the extender to the router through POWERLINE (cabel from router to powerline adapter than again cabel from the next adapter to the extender) in case the WIFI signal is not reaching my upper level?
Thanks in advance!
Chaplain
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 3
Accepted Solutions
Guru
Re: EX7700 combined with powerline
Can you do that? Yes. Will it work great/ok? unsure. Each house is different and performs different with powerline. reason why is many things impact powerline performance including age of the wiring, arc fault circuits, gfci outlets, high draw appliances, electronics going bad/poorly made, or even cell phone chargers can impact it. Plus other things.
So can you do it? yes. Will it work to your satisfaction? we don't know. You'd have to try it and see. Sorry, Wish I had a better answer for you!
Message 2 of 3
All Replies
Guru
Message 2 of 3
Chaplain
Thanks. This would be a last chance in case everything else fails.
Many thanks again for the confirmation.
Message 3 of 3
Discussion stats
  • 2 replies
  • 469 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
