Reply
EX7700 loss of login from D7800
K5Hall
Firmware is V1.0.0.216.
EX7700 is connected to my main D7800 VDSL Modem router.
Using my desktop which is wired to the D7800 I try to login to my extender (EX7700) using Firefox and mywifiext which usually works fine. But I have had problems with this since I have had the extender. Several times now I have used this and just been left with a blank screen. My D7800 is connected to it (as seen by router attached devices page). The only way I can resolve this is to use the IP address which then gives me the login page which comes up as New Extender Setup!. The solution I find is just to power the extender OFF for a while and then power back ON. The extender then works fine.
I have had to do this at least 10 times since I have had this extender and it is still within its 2 year warranty.
NOT GOOD. I would have expected this to be more stable than this over a 2 year period!
Any help/resolution/others experiencing this issue?
No point going back to NETGEAR themselves as they will not talk unless you pay them more money!
Already done this for a long chat and to be given the instructions for resetting!
Also can anyone tell me how many instances of the EX7700 should I see in the D7800 attached devices page?
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 54 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 6E
