- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX7700 not logging into interface
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey guys,
Since the update that happened around September i was unable to connect properly on my Ex7700 with my Samsung galaxy note 9 and other Samsung galaxy note 8. I ressetted it with a pin at the back and it still wouldn't fix the problem and this was back in Septemeber. So today i decided, why not reset it again, so i did. I reset the EX7700 again from the back with a pin, and its connected to my Wifi but when i go to the IP to log into the interface, it says my username and password is incorrect, i reset it 3 times and made sure that my username and password was correct it says "username and password do not match". I also done by security questions to try and reset it but it tells me that it is incorrect.
I actually have no clue what to do? any help would be appreciated.
Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also this might not be the right place to put it as well but the Xr500 I rolled it back to the previous version as well because QOS wasn't working correctly when I was playing games so I ended up using the older firmware for the xr500 that was there before the September update.
Thanks for checking up on me to see if my issue was resolved. 🙂
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX7700 not logging into interface
Hi Opularity, may we know if you are still experiencing the issue?
Dexter
- Mark as New
- Bookmark
- Subscribe
- Permalink
