× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX7700 not working when I connect Synology DS1621+
ChrissiePaul
Tutor
I have recently purchased a Synology DS1621+ and connected it to Nighthawk EX7700.  It worked for one day, then the whole network kept crashing.  I have tried moving the Synology and plugging it directly into the SKY router, but then everything connected to EX7700 stops working in my husband's office.  The WiFi still works in the rest of the house though.  I can't find confirmation that the EX7700 is compatible with the DS1621+, so if it isn't, could someone please suggest an alternative.
Message 1 of 8
Guru
Re: EX7700 not working when I connect Synology DS1621+
What firmware is on the EX7700?
What skybox is it connected to?
What method of setup did you use for the EX7700? WPS or the installation assistant?
Message 2 of 8
ChrissiePaul
Tutor
Firmware: V1.0.0.222
SKY SR203 router
WPS.
All was working fine until we connected the DS1621+.
Message 3 of 8
Guru
2 things you can try.
1. downgrade the firmware a version on the extender. I've seen a few reports of issues on the .222 firmware
2. try installing the extender using the installation assistant and NOT wps. I've seen ISP supplied routers have sketchy WPS setups that cause issues.
Message 4 of 8
ChrissiePaul
Tutor
How can I downgrade the firmware?  I can't find an option to revert to a previous version.
Message 5 of 8
Guru
You download it from the support site.
on that site you go to downloads--->+view previous versions.
download the one you want, then extract it.
then follow the manual firmware process but use the older firmware versus the newer.
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
Message 6 of 8
ChrissiePaul
Tutor
Right, thanks for that.  We have reverted to the older firmware, but still continue to have problems.  I have disconnected all the Synology cables, but this morning none of the tech in my husband's office was working and we had to disconnect the extender to get a network connection.  Not sure what is happening, so I will try disconnecting and turning off everything and reinstalling it all.
Message 7 of 8
Guru
Did you try installing the extender using the installation assistant?
so factory reset it and install it using the assistant and NOT wps.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1261 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
