× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX7700
Withnoname
EX7700
I have tried to update my EX7700 through the app, but asking for my Admin password. To get my admin password I have to login thru the EX7700. NETGEAR_EXT cannot be found. Reset everything, download app try again and get same. Cant use app without password, cant login to extender with out app could anyone offer a solution other than put it in the waste bin and buy a brand that actually works?
Message 1 of 3
Accepted Solutions
DavidRC
Apprentice
Re: EX7700
If you are trying to update the firmware then you might want to think again:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX7700-Firmware-210/m-p/1972650/high...
You can log in to the extender using its ip address or mywifiext.local on a computer (but you will need the admin password).
The other option is a factory reset (and then remember the new password).
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 2 of 3
All Replies
DavidRC
Apprentice
Re: EX7700
Message 2 of 3
Withnoname
Re: EX7700
Thanks, I was going to update but decided against it now...
I will try the reset, it looks like my only option to be able to use the app.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 869 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
