× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX8000 1.0.1.202 Firmware slow 5Ghz
Turbojr74
Tutor
Just did the FW v1.02.202 and twice this cutout after so many hours and would not allow internet connection.  After the second failure, I then saved config settings, downloaded the FW and flashed the EX8000 again.  Did a full factory reset and set it back up.
I am using a R7800 as primary and have a gig network connection/ISP.  From the R7800 I get 400-500 up/down wireless 5G.  Before, I would get about 150 or so from the EX8000 on my computer (uses Qualcomm Atheros AR938x - driver v10.0.3.456).
So far with this new FW I am only getting 50 down and 80up. Slow as hell and I have gone back and rebooted all HW a couple times.
I'm about ready to downgrade the EX8000.
Anyone else having these issues?
What was the fastest speed you got with what FW?
Thanks for any notes on T/Sing this before I try another FW.
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 8
Christian_R
NETGEAR Employee Retired
Re: EX8000 1.0.1.202 Firmware slow 5Ghz
Hello Turbojr74,
Thank you for posting. Curious to know if you were able to run a speed test using another device?
~Christian
Message 2 of 8
Turbojr74
Tutor
Hi Christian,
Very odd that I did not get an email stating you responded to my post as I would have answered you much earlier.
Yes I did try a test using LAN connected devices and then unplugging the EX8000 and running tests.  All of which give me near my 1gb speed.
Message 3 of 8
Christian_R
Turbojr74 - Thanks for confirming. On the extender do you have One WiFi name or Smart Connect enabled? Have you gotten a chance to change the WiFi channels on the R7800?
~Christian
Message 4 of 8
Turbojr74
Tutor
Christian - Hey I got this email notice 🙂
I am using the One Wifi name for mesh.  I have not changed the channels on the R7800.  How would that effect the speed to the EX8000 when connecting to the R7800 is doing just fine with speed?
I did notice the other day that the picture in the EX8000 status showed the 5GHZ output was disabled (for whatever reason as the config showed it was enabled and radio was on), restarted the EX8000 and the 5GHZ output showed green once more and on.  However, this did not change anything regarding the speed...now I'm trying to check it every couple days to see if its off again.  I have never seen that before.  I have not yet gone back to an earlier firmware but thinking it may be necessary if this continues.
Message 5 of 8
Christian_R
Hello Turbojr74 - We have received feedback in previously that changing the channels on the host has helped. Looking forward to your next update!
~Christian
Message 6 of 8
A_Plumbus
I am getting supotimal/poor performance from the 5GHz bands on my EX8000 as well when setup as a WAP and wired into my XR500 router. Did you ever get it to work as it should?
Message 7 of 8
Turbojr74
Tutor
I have not - been hit and miss really.
I can get higher speeds from tested devices just connected to 5ghz of the R7800 in the area where the ex8000 is at.
Connect those same devices to the 5ghz of the ex8000 and there is a significant loss.
Message 8 of 8
Discussion stats
  • 7 replies
  • 2026 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
