- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX8000 Firmware Update Failed. Status Lights Flash Repeatedly and Resetting doesn't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I used the web interface to flash the firmware. The firmware downloaded the update appeared to have completed succesfully; however, upon completion, all of the status lights on the device flash repeatedly. I've tried resetting the extender by holding the reset button down for 7 seconds, but after I let go, none of the status lights are lit. Once I encountered that scenario, I power cycled the device and am back at seeing the status lights flash repeatedly.
I'm not able to connect to the device via it's internal WiFi because neither my phone or laptop detect it. How do I go about getting the extender back to a functional state?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX8000 Firmware Update Failed. Status Lights Flash Repeatedly and Resetting doesn't work.
Resetting can take up to 30 seconds of holding the button down while the device is powered on. Try that first.
If that doesn't work, then try recoving it with a tftp procedure.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure to enable it within windows (if you're on windows).
https://www.thewindowsclub.com/enable-tftp-windows-10
I always recommend updating firmware over a hardwired connection for the best results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've tried resetting by holding down the button for 30 seconds, while the device is powered on, like you suggested. Unfortunately, that didn't seem to work. When I do that, I see the green LED on the back of the device turn to orange and then subsequently blink, but once I let go, the status LEDs on the front of the device remain off (even after letting it sit for 5+ minutes).
I also tried flashing the firmware using TFTP as described in the link provided, but that did not work either. After issuing the command, the result was:
- Timeout occurred
- Connect Request failed
The IP addresses I tried are:
- 192.168.1.1
- 192.168.0.1
- 192.168.0.100
- 192.168.1.250
And I tried while connected to different ports on the back of the device. This kind of makes sense as EX8000 model doesn't have a WAN port. The only ports available are LAN ports. Perphaps I'm mistaken and I'm either using the wrong LAN port and/or I'm doing something wrong.
Please let me know if anything stands out to you and if there's anything else I could try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
here's a video that walks you through tftp. make sure to follow it exactly. As well as make sure its enabled from within windows.
https://www.youtube.com/watch?v=R9DLrLQrpaw
might have to try a couple times
- Mark as New
- Bookmark
- Subscribe
- Permalink
Finally got it by flashing to 1.0.1.192. Flashing to the latest version, 1.0.1.202, wouldn't work. Thanks again for the help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was able to fix my router based on this article and some trial and error. I used a Mac.
here are the steps I used:
1. Using WiFi download the firmware from NetGear site.
2. Disconnect WiFi.
3. Connect to the router using Ethernet cable.
4. Setup static IP address for that Ethernet connection
5. Tftp commands on Mac are different than windows so run
$tftp
tftp> Connect 192.168.1.1
tftp>bin
tftp> put filename.img
(long pause)
uploaded
tftp>
if you get a timeout message then the IP address was wrong and you have to try using a different address.
the blinking light goes dark and after a while becomes green.
6. Then I saw NETGEAR_EXT show up as a WiFi connection and was able to follow new router/extender setup.
- Mark as New
- Bookmark
- Subscribe
- Permalink
