Reply
EX8000 Power Light Flashing Red
eggs4sale
Initiate
Decided to factory reset EX8000 while the power was on (not sure if thats good or not), since I wasnt able to access the internet even if my computer was connected to the EX8000 through ethernet. When I turned it back on Power light was green for a few seconds and then flashes red. I pinged the EX8000 through cmd prompt and I get a reply, however Approximate round trip times in milli-seconds: Minimum = 0ms, Maximum = 0ms, Average = 0ms (not sure if this is bad either). Also tried to reinstall the firmware through tf2p2.exe but nothing seems to be working. Do you guys know any other solutions?
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 3
Accepted Solutions
Guru
Re: EX8000 Power Light Flashing Red
I'd first start with a factory reset. Push and hold reset for 7-15 seconds while its powered on.
If that doesn't help, then you can try recovering with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 3
All Replies
Guru
Message 2 of 3
eggs4sale
Initiate
Thank you so much, I was following the youtube video first, and thought tftp2 wasnt working, didnt know you suppose to use tftp2 on cmd prompt.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1870 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
