× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX8000 USB drive uses "obsolete" SMB1 protocol
RamosWashington
Follower
When trying to access a drive connected via USB3.0 to my EX8000, Windows 10 gave the following error:
You can't connect to the file share because it's not secure.  This share requires the obsolete SMB1 protocol, which is unsafe and could expose your system to attack.  Your system requires SMB2 or higher.
Microsoft supplies a link to SMBv1 is not installed by default in Windows 10 version 1709, Windows Server version 1709 and later ....
Is Netgear going to issue a firmware update which solves this problem?
Message 1 of 2
Re: EX8000 USB drive uses "obsolete" SMB1 protocol
Unlikely. This issue has been around some time.
Did you find this?
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
By the way, you have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 329 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
