× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
EX8000 Wifi Extender Blinking white lights on 10 month old product!!!!
Mark445444
10 month old product, started blinking all white lights acoss the front panel. Called netgear, want 60$ to offer assistance. I see alot of other people with this issue. Anyone able to fix????  Will be our last Netgear product.  Not happy at all with the total lack of tech support on such an expensive item.
Message 1 of 4
Guru
Re: EX8000 Wifi Extender Blinking white lights on 10 month old product!!!!
as the box says, support is only free for the first 90 days. thats disclosed on the box.
If its a hardware failure, then go through the rma process.
but many times the blinking lights can be fixed.
when did it start?
What where you doing with it when it started?
have you tried a factory reset? Pushing and holding reset for up to 30 seconds while its powerd on?
Are you able to ping the extender?
Message 2 of 4
Mark445444
I was in the middle of typing a report when the lights just started blinking and lost connection. Factory reset 8 times. Called tech support and was told firmware issue and Netgear can fix but first I have to give Netgear credit card and purchase a 60$ service agreement.
Message 3 of 4
Guru
you could try recovering it using tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 681 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
