- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX8000 and R8000P setup using second 5G
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi All,
I'm trying to setup my EX8000 with my R8000P. Both are tri-band, but it's not configuring the way I thought it would. I was expexcting the communication between the router and the extender to use the second 5G, but it's using the 2.4G and the first 5G. I would prefer to have them both use the second 5G and not have anything else connected to it. Is this possible? Am I just not understanding how this works?
Thanks
Ron
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX8000 and R8000P setup using second 5G
Sorry, should have said I'm using it in extender mode and I'm trying to extend both my 2.4G and 5G networks using the same names as the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Normally you'd enable fastlane and use one of the 5G radios for the backhaul link to the router. Then the other 5G radio in the extender would be client-facing.
5G-2 is the best backhaul choice since it's the fastest radio (4x4 ac)
Is this how you've set it up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm not sure if it's setup that way or not, but that's want I wanted to do. I'm unclear on whether is does that automatically or not. I can't find a way to change it. Attached is a screen shot of my status page which seems to show that it isn't configured that way, but maybe I'm misunderstanding it.
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It looks like it's connecting to the router on 5G-1 (channel 44). Not horrible, but not ideal.
Can you give 5G-2 on the router a different network name?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, it's named EXTLINK
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then check that the EX8000 is set up to use EXTLINK for it's router connection. Normally 5G-1 is only for lower channels, and 5G-2 is only for upper ones. So that should result in the EX8000 using it's 5G-2 radio to reach the router.
