× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
EX8000 as AP; multi SSID question
iGoldenEye
Star
I currently run a XR500 as my main router with a backhauled CAT6 to the EX8000 as an access point. The 5ghz on both use the same SSID and have worked quite well for seamless switching with mobile products such as phone and iPads. Some of my smart home devices (ie; Ring Dorbell) closer to the EX8000 will connect to the XR500 and cause disconnects going back and forth.
Since the EX8000 has three bands would it cause a problem to keep the 1733mbps 5ghz band the same SSID as the XR500 to keep the seamless "mesh" and use a different SSID for the 866Mbps 5ghz band to connect the stationary devices?
Model: EX8000|AC3000 Nighthawk X6S Tri Band WiFi Mesh Extender
Message 1 of 1
Discussion stats
  • 0 replies
  • 272 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
