- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
EX8000 unreliable after latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try the factory update?
Or the firmware downgrade?
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: EX8000 unreliable after latest firmware
You should take a look at the link states led colour when the disconnection happens. In the latest firmware update a security vulnerability was fixed: https://kb.netgear.com/000064481/Security-Advisory-for-Stored-Cross-Site-Scripting-on-Some-Router-Ex...
Here you can read more: https://www.netgear.com/about/security/
Downgrading is also possible: https://www.netgear.com/support/product/EX8000.aspx (previous versions)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anytime I see an issue after a firmware update, I usually recommend a factory reset and reinstall.
Sometimes old settings can cause issues.
If that doesn't help, you can always downgrade the firmware. Always something to be said for stability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The LED colour is important because that gives information about the signal strength. When the extender have a very poor connection to your router, you will get disconnects. That is why I mentioned it. But if it just happened after a firmware upgrade and you didn't move it, than the chances are high that is related to that upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Reads for me like two changes had applied on the network - a new (unspecified) router, and the EX8000 firmware update. Where the later one mainly includes some security fixes to avoid a possible command injection on it's management environment.
- Mark as New
- Bookmark
- Subscribe
- Permalink
