Agee
Aug 31, 2015Aspirant
Entending wireless coverage Netgear19
I have a NETGEAR19 Router and need to entend the wirelass coverage of my 2900 SqFt home. The Router is in the office at the rear of the home and the coverage is weak in the front of the home. What is a good dual band extender to purchase to increase the signal strength to the front of the home? Thanks - Agee
- nhannNETGEAR Employee Retired
Hi Agee,
I've linked to the NETGEAR extender page where you can perform comparions to fit your requirements:
http://www.netgear.com/home/products/networking/wifi-range-extenders/Another solution is the NETGEAR powerline, which you can use if the office is using the same electric wiring as the home:
