× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ethernet cable issue with WN3000RP
dinty
Follower
Although the extender is working on wifi the cable connection via the ethernet port indicates connection but is not connecting to internet ?
Has anyone had or solved this problem Thanks
Message 1 of 2
Fairytail
Virtuoso
Re: Ethernet cable issue with WN3000RP
Have you check if you are getting valid IP wired from the extender.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 11374 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
