× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ethernet name changed while installing my Netgear Repeater AC750 EX3110
Akkifriman
Follower
Hi! While installing and setting up my Repeater I discovered after having comitted the installation that my cable connection to WAN via my ASUS router changed from just Ethernet (connected) to a subname including my wireless net name +" _5GEXT"- Why? and HOW?
I would like to edit that but how?
Akki
Model: EX3110|AC750 Dual Band WiFi Range Extender
Message 1 of 3
Guru
Re: Ethernet name changed while installing my Netgear Repeater AC750 EX3110
Your ethernet name on your computer changed?
That'd be a function of windows network profile.
https://www.howtogeek.com/364291/how-to-change-or-rename-the-active-network-profile-name-in-windows-...
If that's what you're meaning. If not, a bit more details on whats going on might help
Message 2 of 3
Guru
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Akki
Message 3 of 3
Discussion stats
  • 2 replies
  • 595 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
