Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ex2700
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-10-23
04:40 AM
2020-10-23
04:40 AM
Ex2700
I have connected the extender to my router, but when I try to connect my phone or iPad it says the password is wrong. But it says to use the current router Password. I have checked the password and it is correct. Can anyone help please. I’m not very technical so basic advice would be great please! Thank you
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-10-23
06:00 AM
2020-10-23
06:00 AM
Re: Ex2700
What router are you connecting it to?
What firmware is on it?
Did you set it up using wps or using the installation assistant?
I'd highly recommend using the installation assistant if you didn't. Factory reset the extender and reinstall it using that method. don't use wps.
Current setup: CM2000-> RBE973S-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/100mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Announcements
