× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Ex3110
Queenbee794
Follower
Ex3110
I purchased a new AC750 extender and it does not connect. I’ve followed instructions to the letter but it never connects. What may be the issue?
Message 1 of 2
Guru
Re: Ex3110
what router are you connecting it to?
What method of install are you using? There's several different ones.
If the first fails, I usually recommend the next.
Did you set it up using the push button WPS option?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 437 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
