Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ex6100
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-06
08:53 AM
2020-12-06
08:53 AM
Ex6100
Hi, I am having problem with my EX6100 WiFi Range Extender Installation Guide. I used this adapter before and it was a connected to my old wifi. Now that I try to install it again it seems like it connects to my new wifi but the names that appear in the adapter are my old wifi, I try to put the wifi of the new router but it does not work. I don’t understand how it still has the name of the old router because it was from6 years ago meaning that it was gone 6 years ago meaning its not in my house anymore meaning that I don’t understand how is connected. I try to reset it in the factory reset but it did not worked. So I was wondering if someone can help me with this problem, I would be really grateful. By the way my wifi router is WPS not WEP. Thank you!
Model: EX6100|AC750 Dual Band WiFi Range Extender
Message 1 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-06
09:12 AM
2020-12-06
09:12 AM
Re: Ex6100
wps is a method of setup.
WEP is a security method.
What router are you connecting it to?
What you factory reset it, did you push and hold reset for 7-15 seconds while the extender was powered on?
then reinstall it using the guide. Don't use wps, use the installation assistant.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-08
07:50 AM
2020-12-08
07:50 AM
Re: Ex6100
It seems they have shut off support for setting up this extender
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-08
07:52 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-08
08:16 AM
2020-12-08
08:16 AM
Re: Ex6100
When I've tried to go in and reset the extender thru it no longer works and is no longer listed as a supported device on the set up webpage
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-08
08:37 AM
Announcements
