Sabrina33's avatar
Sabrina33
Follower
Jul 26, 2024
Ex6120 connected to router but no internet
As of 7/22/24 my range extender stopped passing internet through. Factory reset, set up several times. Updated firmware, downgraded firmware, bought a new device and same outcome. ISP says they don't know why, netgear cs also doesn't know.
Router and extender both show connections but there is no internet when connected to the extender.
Help!
1 Reply
    Help!
    Since your range extender stopped passing internet despite multiple setups, firmware updates, and even a new device, the issue might be with the router's settings or a compatibility problem. Ensure the extender is properly configured to the correct Wi-Fi network and channel settings. Check if there are any IP conflicts or MAC address filtering on the router.
