× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ex6120 extender suddenly stopped connecting to internet
Robitaker
Follower
Set up was perfect 6 months ago, worked great until a few days ago. It won't connect with my router. It powers up green light, I can connecty device to it. But that's it. I tried factory reset, reset router, clear cache, everything I could find in the troubleshooting section and still nothing, still the same. Is it defective? Worked great, nothing was changed with set up or location, it just started to do this, thanks for any advice.
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: Ex6120 extender suddenly stopped connecting to internet
What router is it connecting to?
Are you setting it up using wps?
What firmware are you on?
Message 2 of 2
Discussion stats
  • 1 reply
  • 325 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
