×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Ex6120 on iphone 7 weak security need help for firmware updates
Al0483
Follower
Message 1 of 3
Re: Ex6120 on iphone 7 weak security need help for firmware updates
Not sure that anyone can help much with this. Trying to pack everything onto the subject without explaining things isn't going to get us very far. That what the Body bit of the message is for.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
Guru
What security are you using? WPA2 is standard.
there's a newer wpa3 standard but you'd have to upgrade hardware to get that.
And apple devices are great at giving you a notice that "your security is weak" when you're not on the latest devices.
Quite a few devices still use wpa2 perfectly fine.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 249 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
