× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ex6150 security update madness
Kenny66
Follower
I hope someone can help maybe answered many times before.
I have downloaded a patch patch for my extender ( first time in a long time ignored previous others)
ok when I follow Instructions to input 192.168.1.1 it takes me to my routers home page not NETGEAR.
when I type www.mywifiext.net it takes me to create new account and that’s it a dead end, no login , no page where I can access my extender and apply the update.
Please help
thanks
Model: EX6150|AC1200 WiFi Range Extender
Message 1 of 2
Guru
Re: Ex6150 security update madness
If you go to your routers attached devices page, it should list the ip address for your extender. You can use this to access the extender. Another option is to hardwire into the extender via its ethernet port (recommended method of updating anyway) and go to the mywifiext.net.
Many of the extenders are now using an account login to access the device. If you didn't set this up, the fastest method might be to factory reset the device and go through the setup process again.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 987 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
