- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ex6150v2 latest update (v1.0.1.108) prevents further login access
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello. Yesterday I logged in to my EX6150v2 Wifi Range Extender, upon checking for updates it indicated that update v1.0.1.108 was available. I downloaded and installed this update but now am unable to login to the device.
I am presented with the login screen, on entering the correct login details a brief (one second) screen flashes up and then the login screen re-appears ready for me to enter the login details (again).
I filmed the brief screen flash and on stepping through the video this shows:-
You have more than one Wifi Range Extender in the Network. Please select the extender that you want to login.
IP address MAC address Device Name
(There is no further information)
I now find that I am now unable to contact Netgear Support as my support options have expired. The latest update has trashed my device and I can't even discuss it with them! Under those circumstances I will never buy Netgear devices again.
My next move will be to Factory Reset the device and try to re-configure.
Has anyone else experienced a problem with this update (or have a solution)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6150v2 latest update (v1.0.1.108) prevents further login access
I would try the factory reset/reinstall option.
Sometimes old settings can cause issues when upgrading/downgrading firmware and thats where a factory reset can be beneficial.
