- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ex6200v2 Ethernet droping connection every 20-30 minutes
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ive been having problems with m Ex6200v2 where ive been using for ethernet on my gaming pc and when i play any game about 15-30 minutes into something it just disconnects me for about 15-20 seconds and it happens wtih the game and my discord itll go from 4 bar to a 1 bar then drop out completely then reconnect. ive tried everything its on the latest firmware ive done resets ive switched channels idk what to even do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ex6200v2 Ethernet droping connection every 20-30 minutes
My router/modem is a arris TG2472
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello ixncxlxkxxth - Have you tried connecting another device wired into the extender to see if the behavior is the same?
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ixncxlxkxxth - When you connect the laptop directly to the router, does the same issue occur?
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
the laptop doesn't drop connection its my pc that is custom built into my desk is and my router is in another room. Sometimes with the xbox when it is on ethernet it drops connection to the ex6200v2.Ive used the ethernet port on the mobo and i got a pice network card and it still drops s oi dont believe its hardware based
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi ixncxlxkxxth,
A couple things:
1. You could try reserving the IP address of your pc on the router so it does not try to assign it a new one every time it is turned on
2. What is the status of the router link LED when it drops?
3. Have you tried switching out the cable that is connected to the extender and pc?
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
2 all the lights on the router stya connected im pretty sure but i cant move that fast to see the lights when it times out
3. Ive tried at least 15 different cables
- Mark as New
- Bookmark
- Subscribe
- Permalink
ixncxlxkxxth,
You will need to log into your Arris router to do so. Please contact Arris Support for further assistance.
Furthermore, please contact our Technical Support Team for further investigation : https://www.netgear.com/support/default.aspx
~Christian
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
