× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
Expand WiFi / connect repeater
Gecky
Follower
Hello,
I bought a wifi repeater and it totally worked.
But, I still have to cover a larger area.
My question is: Is it possible to connect two repeater to cover a larger area. Concrete, I already covered my living room and now I want to place another repeater in the corner to cover my garden. The issue is that I cannot connect from there to the router, so I have to connect to the already existing repeater EX6120.
I would be thankful for any comments.
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: Expand WiFi / connect repeater
You can daisy-chain the extender (connecting through another extender), though performance will drop because of the additonal hop.
You might consider powerline instead (for instance this: https://www.netgear.com/home/products/networking/powerline/PLW1010.aspx)  That would connect back to your main router through your house wiring.  Performance will depend on the details of your house wiring (and the circuit load)
Message 2 of 2
Discussion stats
  • 1 reply
  • 403 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
