×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
Extend WiFi range in an apartment without wired hookup
RJoanR
Follower
I have used a Netgear Router in my home.    I will be moving into an apartment building for persons over the age of 62.    The building has free internet in the common areas and you are given a password to logon when you move in.    There is no hookup in the apartment but I did pick up on the network on my cellphone while touring the apartment.
I have been reading about WiFi extenders and am now completely confused.   If I do not have physical access to the building's modem/router, how do I set up an extender and what would be my best option in equipment?    I spend a considerable amount of time online (laptop, streaming tv/movies, and cell phone).
Model: Dual Band
Message 1 of 3
Guru
Re: Extend WiFi range in an apartment without wired hookup
I recommend you post here in the extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 3
SImonZzzz
Tutor
I'm no expert, but pretty much any Wifi extender should work for you. You simply plug it in, log into the configuration page of the extender, look for the wifi signal you want to use, and attach to it using the password they have given you. And hey presto, you'll have a much stronger wifi signal in your apartment. I have just bought an EX2700 which arrived today. I'm having a couple of nerdy problems with it, but frankly, it seems to do the job. and it's really cheap.
If you want to get nerdy, you might want to find out if the network you'll be using also has a 5G channel (the EX2700 only uses the 2.4G band) but we're probably splitting hairs.
Or...You may be able to use your existing Netgear router to do the same thing, and not spend a penny extra. Post the model number here, and I'm sure someone will tell you how to set it up as an access point or wifi extender. You might want to log into your router and see if it has options for this yourself. The process is exactly the same as with an extender.
Model: EX2700|N300 WiFi Range Extender Essentials Edition
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4147 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 6E
